Acura Coupes and Sedans 1994-2000 Repair Information Print FShow me a picture where the fuel pump relay is loc - 0900c1528008be05.jpgc of the PGM-FI relay Fig. Fig. 2: PGM-FI relay terminal numbers
PGM-FI Main Relay
This relay is located behind the dashboard's lower cover. It consists of two individual relays. One is energized whenever the ignition is ON , thus supplying battery voltage to the Powertrain Control Module (PCM). This relay also supplies voltage to the fuel injectors, and power to the second relay. The second relay is energized for two seconds, when the engine is turned ON , toShow me a picture where the fuel pump relay is loc - 0900c1528008be04.jpg.
See Figure 1
Testing
If the engine starts and continues to run, the PGM-FI relay is working and does not need to be rShow me a picture where the fuel pump relay is loc - enlarge_icon.gif>
See Figure 2
It is in the fusebox beside the fuses. black box
SOURCE: 1990 Acura Legend, location of main relay for fuel pump
looked it up online, looks like its in the underhood fuse box but couldn't get a good diagram that shows which relay number it is. the website i use is sort of dependent on the manufacturer, apparently acura did not feel like sharing that info. hope that helps
SOURCE: 1994 toyota fuel pump relay
Fuel pump relay is in the engine compartment left side fuse block
SOURCE: Where is the fuel pump relay located on 1997 acura
you should find it under the hood in the main fuse box you will have to look in your handbook to pin point its location normally black 5 pin
SOURCE: 91 acura legend will not start
Take off the hose to the throttle body and look for any obstructions. This has been know to cause performance issues similar to those described
SOURCE: where is fuel pump relay
where is the fuel pump located on my 1994 acura legend and how to check the relay and where is it located
