My sony Bravia is stuck on the Bravia Screen when you turn the power on, can't do anything, the remote is useless also help please
"Bravia Screen". Not sure what you mean. Is it in maintenance mode?
Option 1.. With the tv plugged in and the power OFF (this is called standby mode) take your remote (make sure it has fresh batteries) follow this sequence on the remote. You have to press the buttons within a second of each other in this order:
DISPLAY - 5 - VOLUME + TV POWER.
When the screen comes on hit JUMP right away and it puts you into a little screen for maintenance. Simply turn off the television to exit maintenance mode.
2. If your remote is bad, ie, new batteries don't fix it, might suggest a new one.
3. If you can't get a new remote, power on the television using the power button and then hit the menu button. Use the up and down keys to see if you are stuck in some weird screen or something.
4. If you are connecting something to the television (like a dvd, a playstation, computer, etc) try unplugging everything and test each port individually, using the side buttons as described in part 3 to change the input mode to the port you are using.
Hope this helps
SOURCE: Sony Bravia TV went Blank
COULD BE LVDS CABLE LOSE OR NOT MAKING A GOOD CONTACT , IF IS NOT THAT UNFORTUNATELY IT WILL BE NECESSARILY TO REPLACE T CON BOARD
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
THANKS
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TV will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
