Maytag MMV4205 Microwave Oven Logo
A
Anonymous Posted on Mar 09, 2013
What's the size of model mmv5000BDw - Maytag MMV4205 Microwave Oven
How do you access the fuse in a Maytag Model#MMV5000BAB
Maytag Model #MMV5000BAB
Hello Karen Smith,
I think it would be nice to tell you MORE DETAIL... (sorry).
Typically the fuse OPERATES because the magnetron is getting burned out... but HEY fuse is cheap... check out the parts houses below (just that getting an UNDERCABINET down each time can be a SERIOUS PAIN.
"appliancepartspros" will let you order the parts and return
THOSE UN-USED
parts... (pretty handy).
MOST likely from poor use & abuse...
I watched my sisters grand kids warm "butter pats" in her NEW convection micro-wave. It was VERY short lived...!!
There's A REASON they advise not operating them EMPTY. With care (reading instructions) some actually do get OLD.
https://www.bing.com/search?q=maytag%20magnetron%2C%20model%20mmv5000bdw&qs=n&form=QBRE&pq=maytag%20magnetron%2C%20model%20mmv5000bdw&sc=0-34&sp=-1&sk=&cvid=70C1AA9D41A24B32B6984A918DCCAE9B
Maytag Microwave MMV5000BDW PartSelect
http://www.appliancepartspros.com/parts-for-maytag-mmv5000bdw.html
and on-line video
Maytag Microwave Not Heating
My model mmv5000bdw
Most likely a fuse or thermal cutoff device (TCO or thermal fuse), usually mounted on top of the oven cavity, between the oven cavity and the outer cabinet panel.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Where is the fuse on the mmv 5000 micro wave
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Your full model number will be one of these:
MMV5000ADA
MMV5000ADB
MMV5000ADW
MMV5000BAB
MMV5000BAC
MMV5000BAQ
MMV5000BAW
MMV5000BDB
MMV5000BDC
MMV5000BDQ
MMV5000BDW
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
1helpful
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
I lost the underside light bulb and cannot find the specs to purchase a new bulb. What is the bulb type, size, etc?
You didn't mention your brand or model, but here is a generic answer.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Be sure to unplug the oven before you remove or insert the bulbs, or circuit board damage can occur. We fix that, too.
1helpful
Maytag mmv5000bdw Touch panel works intermittently The panel will not respond to the touch. Work around include: 1. closing the microwave door hard and trying again. 2. unplugging the microwave and trying...
If nothing works, it sounds like you didn't get the cable inserted properly. It should fit into a connector which carries signals to the microwave's control components. These connectors usually pullup, you insert the cable, and push the connector back down.
1helpful
MMV5000BDW Touch panel works intermittently
You have a failing keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
