Need help
I have a Panasonic Plasma Model TH-42PW6 and panel part no. MD42S06B1J.
But when I order from Panasonic center they give a Plasma Model TH-42PW7 and panel part no. MD42S07A1J.
After replace to the panel part no. MD42S07A1J.to TH-42PW6 set and the picture have saw tool on the picture image.
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
I had the same issue twice with a TH 42PWD5. turns out it was my UPS that was killing the switching power supply. Warranty covered it but when I removed the UPS not a single issue in 3 years.
SOURCE: Panasonic Th-50PX60B... Need HELP!
The power supply, and or some other board in the set has probably failed, and the supply is in the protect mode.
These sets are not serviced at the component level unless the fault is very simple. They are serviced by swapping out the modules.
As for the schematics, the service reps mainly use functional diagrams, and use the factory level alignment sections. They replace the failed modules and then do any necessary calibrations according to the service set-ups. At home I don't think you would have the necessary facilities and tools to troubleshoot the set and to do any of the calibrations if necessary.
As for the electrical power, is there any difference between where you are and back in the UK? If there is, and if you did not use the proper power conversion equipment the set was probably damaged.
Another aspect to look at is if the broadcast system is different between India and the UK. If so, the set will not be able to receive any programing without the proper conversion process. Signal conversion will add some quality loss.
I strongly think your set may not be compatible to the standards for the country where you brought it because of the fact that the set is not locally supported.
I am located in North America. When I was working in TV service we had people bring TV sets from different parts of the world. There were both electrical and signal standard differences. In the end, they had to buy a new TV set that would work locally. The foreign set ended up being a useless monument in a storage room.
Jerry G.
SOURCE: broken glass - 42 panasonic th c42hd18
usually not very cost effective to replace the front screen. id say around 70% of what you paid for the tv.
SOURCE: i have a plasma panasonic viera TH-42PV60A stand
Not power supply,it the backlight video board it dead.
Testimonial: "cool thanks alot"
