I turn it on and it will only stay on for about 2 seconds then it shuts off by its self it started doing this wwhen i was listing to my music pretty loud with my surround sound what do i do??????????????????????
What happens before it shutting off itself?
Are you sure that the timer off isn't on?
Normally, the self off may happen because the TV goes into Protection Mode due to a failed circuit board.
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
One thing to check into would be the antitheft system. Not knowing what year or type of vehicle makes it hard to help. But like i said, engine shut down in 5 seconds or less is a symptom of a bad antitheft security system. This link explains. http://vatspasslockpasskeysecurityhelp.yolasite.com/
check fuel pressure, should be 40 psi.
try 2 things
spray starting fluid in air intake to see if it will stay running. It's fue then.
Try turning key to on nd wait 5 seconds for system to build pressure and pump to shut off. Turn key off, wait for relay clcik noise or 10 seconds. then turn key to ON again and wait 5 seconds to build pressure again. Then start engine. If it starts better, you have a bad check valve in the fuel pump or a bad pressure regulator on the fuel rail (unlikely).
The first couple of seconds of operation, most TVs are doing some self-test and if something has failed making full power on dangerous (for fire) they will shut down.
Either a major component in the horizontal section has failed or the main power supply itself is defective.
if it starts and warms up does it shut it self off or do you shut it off an then won't restartif it shuts self off may be runnining it self out of gas wwhen it shuts off try spraying a little starting fluid in breather and see if it will recrank if it does you have a fuel problem if it does not start you have an electicly problem such as a bad coil poss
