SOURCE: how to open it to change the electric cable ?
I'm looking myself for a guide to open it fully, but I can at least answer your question partly. Maybe you can get on from there.
When you look at the front side of the mixer(the side opposite to the cable), there's a slim oval lid with rounded ends. Push a small flat sdcrewdriver under that lid until it pops out, revealing a screw. Remove the screw.
The rest of the enclosure seems to be held together by several hidden plastic clips. Use a pocket knife with a thin blade and push it carefully between the halves of the case. Work your way from the screw to the top and bottom side, levering the halves apart step by step. Do not use too much force!
I'm stuck at the back of the case where the rubber ring is. I can't get this part open., but it's a start
SOURCE: Braun MultiMix 880 became a one speed. Is a
Apparently the switch is very easily available, unknown for what reason. In Europe they say it is not available at all anymore, which I find strange.
However!
Dissasemble, by removeing base plate and screw underneath curved retainer plstic clip in the front. Then gently pry apart with blunt, thin object to split the two halves. Remember to unplug the power cord first. Check the circuit board for cracks, or burnt components. Then suspect the triac/tyristor. Desolder it and test it with a multimeter. (google "test triac multimeter"). Then note the code on the front of the triac, and search for a supplier of electronic parts to get hold of a new one and solder it back on. Note the orientation of the pins, and reattach heatsink if fitted. (Euro version have non.)The triac often looks like a flat design transistor and have a code/part nr that may look like; TCI 226 N, as on my European 230v version. Electronic components suppliers also have interchangeability lists for different manufacturers and use cross reference lists. Should only costs a few dollars or so. Triacs tend to stay fully open when failed, causing full speed in any mode. It is worth a shot.
SOURCE: I need a chopper attachment
See
http://www.smallappliance.com/product.asp?pid=5623&cur=USD&sid=18956&mid=5&gid=18978&prdCls=P&PartsPaNu=1&shopBy=Brand
(2 pages)
And you will find spare parts online for your braun which i believe is model nr 4642 (se baseplate).
For a chopper attachment; you may need bowl plus rotating blade.
You may also use braun's own spare parts finder at:
http://www.service.braun.com/product/product.asp?rg=NA&c=US&l=GB&typ=pf&frmTyp=s&grp=0&s=4642&subgrp=&des=&sgrp=s&sString=4642'HH'HH06'H'MultiMix&seite=2
But you will have to contact one of the authorised service partners to buy.
SOURCE: braun multimixer m880 the motor has finally died,
See
(2 pages)
SOURCE: My Braun Multimix 280 will only operate on
Yes. You can do two things. Replace the swith curcuit board or replace the triac/tyristor on the board itself. The last solution requires you to unsolder the triac and loosen it from the heatsink(110v veriosn only. 230v version has no heatsink) and test it with a multimeter to establish if it has failed. (Testing of tracs can be googled.) In eather case you will need to open the casing.
1. remove the base palte by lifting the end opposite to the electric cord.
2. Loosen the bottom power outled slider, without removing it fully
3. unclip the curved plastic retainer in the front and unscrew philips head screw.
4. Work around the edges of the two halves until it comes apart and you are able to free the slider from its return spring.
Replace the cicuit board completely if available. Or resolder a new triac observing the orietation of the pins and reattach to the heatsink by riveting/cliping on or whatever applies to you model. Using heat conductive silicon paste between triac and heatsink is a good idea if it is originally fitted (if white paste residues can be seen). The European 230 v version do not have a heat sink, due to the higher voltage and thus lower current opassing through. If the Euro version, simply replace the triac, trim the pins on the back of the board nad put back in place.
Triacs can be obtained from any electronic componets dealer, as long as you can supply the code stamped on it. The Euro version has code TIC226N, which you can find in any component or manufacturer cross refereanse table. TIC226N basically means a 8 amp triac. Triac is simplified just a sort of ac transistor. The US version I do not have the code for, but it must have a higher ampere rating, thus the heatsink
To replace;
Put all internal componets back in place in the right halve. Put the left halve on top and fit properly by gently pressing together. Fit the screw in the front and the retaining clip. Fit the sliding cover by cliping it back on, observing that the notch for the return spring will meet the spring pin on the right side for it to snap in place. The spring pin can be observed through the slots for the sliding cover. Then insert the base plate reversely of how you removed it.
The problems of these mixers, is that if overloaded the maximum current rating of the triac's may be exceeded. This will cause the triacs to short curcuit and therefore will give full power in any mode.
To avoid the problem, avoide heavy batters, heavy doughs and prolonged high load tasks. Otherwise a very handy smart little mixer that should last for years.
