Cleaning behind the glass on Maytag built in ovens.
You should have a 2 piece glass in your oven. What has happened is that the seal that separates the 2 pieces has come apart or is broken thus allowing air and grease in. You can take apart the glass but it will only be temporary for about 2-3 months and will get dirty again. The bad thing about it is that te more you take it apart, the more the band that separates the 2 pieces becomes out of its form, the harder to put it back together. Unless you don't mind it, I would leave it alone or just replace it and be done with it. The question I have is, is the glass cracked or has the door been bent? Normally, the glass lasts for nearly the life of the oven.
Actually, this is the kind of oven with the floating glass front. I'm trying to clean in between the two floating glass pieces not the oven glass behind them. But thanks anyway.
