Frigidaire front loading waher stopped at rinse /drain cycle. When I turned it off and tried to restart the rinse/spin cyle I get three (3) beep error code which states, "Drum overfilled." and suggests cause of problem to be, "Inlet valve or control board failure." Solution suggested; "Do not open door, select Drain/Spin to remove water, restart cycle." i followed these instructions. Washer drained some of the water and stopped again. Any further attempt to restart gives a hum, a 30 -40 second low noise and a stop. I have un-plugged the washer, even for one day, to clear any control board logic hung up but no luck. What is your suggestion? How do i determine whether I need a control board or an inlet valve? Where can I purchase either component and roughly how much?
My washer is barely 2 years old. Help!
Frustrated and disappointed owner.
George
this morning when we turned on the washer it started to make a clicking noise in the black box on the back of the washer (water inlet assembly) and hot water started to drain. After that we turned off the washer but the hot water kept draining.We turned off the hot water supply. We removed the back of the washer to inspect it. The drain valve was open.
How can we fix this?
