when connected the screen blanks out every 8 or so seconds , def not power issue , stumpedwhen connected the screen blanks out every 8 or so seconds , def not power issue , stumped
AnonymousMar 19, 2014
when navnet vx2 starts screen display becomes unstable blacking out every 10 seconds or so, dc power is stable thinking it may be a Navnet vga output issue.when navnet vx2 starts screen display becomes unstable blacking out every 10 seconds or so, dc power is stable thinking it may be a Navnet vga output issue.
You can't post conmments that contain an email address.
Go to Furuno's website and you should be able to download the manual. There are also DVDs you can buy but I felt they were all too general to be of any help, so I wouldn't waste my money on those.
n the system setup, under “UNITS” I set
BEARING to “MAG” (magnetic). This will cause the unit to display course /
bearing information in relation to the Magnetic North and match magnetic
compass readings. It is not the same as True North! One has to be careful with
this setting. There are a number of areas where the earth's magnetic field is
locally disturbed, sometimes very significantly. Your GPS may not account for
it.-again, under “UNITS” I set “METRIC”.
That is a Furuno 1823C Radar -000-138-972 (10 meter Radar cable) $150.00 msrp from Furuno. Give their Camas Office a call or your nearest dealership. The Furuno number in Camas, Wa 888-834-9330
This is a bit of bummer. Usually (and I hope in your case too) it is just a software problem. As a navnet is basically a computer this can happen. First I suggest you unplug everything except power and start it up, just to see if something on the network port isn't messing it around. If it still gets stuck take it to your local Radio Holland office or another furuno certified service outlet to reload the software.
Reinstall the operating software.
The unit should probably go to Furuno.
Try operating it with only a GPS connected (no radar, no network). If this resolves it, it is almost certainly software. It could be low voltage or failing mother board.
