Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Posted on Mar 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the suggested color settings for 60pp9100d?
Anonymous
Level 3:
  • Philips Master 3,459 Answers
  • Posted on Apr 19, 2013
Anonymous
Philips Master
Level 3:
Answers
3459
Questions
5
Helped
849305
Points
5558
I suspect you are asking about the convergence or brightness. See below for both common problems and fixes
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button onlWhat are the suggested color settings for 60pp9100 - 47a7bc4.pnging the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set thaWhat are the suggested color settings for 60pp9100 - 7c190d8.jpg fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFOREWhat are the suggested color settings for 60pp9100 - a798d23.jpg>7c190d8.jpg
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
4answers
I have a phillips 60pp9100d that has no picture or sound. I keeps flashing I2c bus error. I have resoldered the flyback connections and anything else that looked suspect. After turning the tv back on I get...
You need to rectify the problem first then replace any part. If you have its service manual, try to daignose the reson of error and locate the problem area.
60pp9100d/37b is stuck in hd cvi mode how do i get it out
Stuck on digital tuner? There's buttons on remote for analog and digital tuner mode.
The color is off there is too much red in my 60pp9100d/37
Philips TV's have a reputation of bad coolant fluid. This fluid is found between the picture tube face and the projection lens. The coolant starts turning a milky brown color and causes the picture coming through it to be degraded. This envolves removing the picture tubes and changing the fluid. This is a very complicated repair because it envolves convergence adjustment after it is reassembled. Most shops charge about $300-$400 bucks to do this. Have a shop check it out for you and make sure that is what the problem is. Thanks for using fixya. I hope this gets you on the right track.
Philips 60pp9100d/37 - remote sensor
Yes it probley got pulled out and since
its a stragler wire ,it would be easy to miss
little trick I use is never dust or vacume
till your done , that way you can see where
somthing was or was not pluged in at that
location
darn gota take it apart again , I know the feeling.
1helpful
2answers
Philips 60pp9100d/37 convergence issues
Did you replace the 6.8 ohm 1watt resistors? As that model will usually blow a couple when the ICs fail.
Philips 60 inch projection
The I2C message that you get means the Inter IC communication bus on the system board has gone bad. Replacing the IC would not solve the problem.Philips patented this technology to reduce the number of ICs on the systemboard.There would be a physical I2C chip on the motherboard.
You can read about the technology on the post by philips
http://www.nxp.com/acrobat_download/applicationnotes/AN10216_1.pdf
I would suggest update the firmware on the board, or try replacing the I2c interface controller chip.
Thanks
Proton
3answers
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
PHILIPS TV MODEL # 60PP9100D/37
check your speakers, your cables going to speakers and try to use a headset, if you hear sounds in your headset the problem is your speaker .
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
