Mitsubishi WD-65738 DLP TV Logo
joseph Posted on Mar 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
65738 colors flickering after bulb replacement
bobby caesar
Level 2:
Champion:
  • Expert 247 Answers
  • Posted on Jul 14, 2013
bobby caesar
Expert
Level 2:
Champion:
Answers
247
Questions
Helped
28486
Points
498
Check the colour wheel in the light engine most likely bearings are worn needs replacement and the colors will stabilize need to open the light engine and replace with a new one
MY TV TURN ON AND OFF IN 1 MINUTE
The bulb is faulty connection or inverter failing
Mitsubishi 65 dlp
SOUND LIKE A BAD COLOR WHEEL...HEAR A LINK TO SEE IF THAT THE SOUND YOU ARE HEARING ....http://www.youtube.com/watch?v=hUiYRqrNxxU
Mitsubishi wd-65738 flickering
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
3helpful
3answers
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
1helpful
I have a mitsubishi wd 65738. My picture suddenly went dim. I can still see a picture but the room has to be very dark and its still hard to see. Do I just need to replace a bulb?
Hello
Its bulb has got traoubled or its control circuit has some faut with it. it is not a user serviceable item. Replacing bulb can be done by the user according to the instructions in its user manual. But trouble shooting its control section must be done be any experienced service technician. OK.
Flickering Screen/Line in Screen
flickering is a sign that bulb will go out soon. Also check if the bulb fan is clean and running.
2answers
Blending Colors/Flickering Display
Hi SmartMex
This in not a lamp problem , but rather a Mainboard issue.
You will have to take it to a Service Centre to either be repaired or replaced.
Sharp Projector XV-Z90 Flickering
the color wheel is dirty. It just need to be cleaned.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
