Go to Settings > Sounds > Change the settings to Ring+Vibrate or Ring Only or Vibrate Only
I guess you have by mistake changed the settings right now to Ring Only Once and hence it rings just once and then vibrates. If there is not settings icon and no sounds option you can check if you have Profile as option as you can change it accordingly in the profile you are using. Hope this helps. Good Luck
