Televison & Video Logo
Anonymous Posted on Mar 07, 2013
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but after 20 seconds it starts to flicker with strange colors (also the same time this starts a whine starts from the rear) then tv shuts of
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Mar 07, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
751
Points
10
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
  • Anonymous Mar 08, 2013
    I will give it a try
    removed both fans and cleaned all the dust. plugged the tv back in and saw the fans working. but the problem still is there.
How do I fix a mitsubishi tv that shuts off and has a steasy red light
Replace your lamp. Make sure its a real Osram bulb and not some cheap knock off. These folks have Osram bulbs and a 6mo warranty. Projector Lamps and TV Lampson Sale ProjectorLamps com stocks Superior...
I have a WD-73642 tv has no picture but has sound
I had this problem with a laptop of mine it's the led just replace the screen
3helpful
73 mitsubishi dlp tv 73737 has sound but no picture with red light in frount
You need a new lamp. The red light means the lamp failed to turn on.
You can find cheap ones on ebay for about $40. If you go to best buy they will charge an arm and a leg. You can change the lamp yourself and it will take less than 15 mins to do. The only tools youll need are a phillips screw driver and maybe a flat head.
Mitsubishi 73 inch wd-73738 no picture
Take a flashlight and at a angled view see if you can see the picture, if you can the lights burned out in the back
1helpful
2answers
Can hear the sound on my 73 inch mitshubishi, but no picture at all..no black and white..nothing. After a few minutes the led red light in front that says "Lamp" comes on? What's the problem and how do i...
you need to replace the lamp inside the DLP TV. they are about $400 or so depending on your are. i would google the best price and find the must trust worthy TV repair place or call best buy.
I heard a popping sound in my tv, then it shut off. I turned it back on with no picture, then the green light went off and the red light came on. Is it the lamp?
yes , the lamp went out , u can get a shipone over the internet or buy the original from mitsubishi , i recomment the mitsubishi
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
