Model # c50md2l 6/96 50 pound front speed queen. blows fuse once every 20 or so loads.
SOURCE: Kelvinator or (Speed Queen Top Load washing machine)
I have a Speed Queen AWM373W top loader with the same problem. We recently had the kit and belt replaced because it was leaking water. That is fixed now but it takes forever. The other night I tutned the drum by hand and it worked fine. Did not had the same problem since but I am watching it.
SOURCE: Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
SOURCE: 28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
SOURCE: At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
