I forgot my pass word to my proscan plt8031 tablet
This is everything you need to know to root/unlock/factory reset your Proscan 8" Tablet a.k.a. PLT8031.
First thing you will need to do is charge up your device, download the software needed to your desktop or some other easily accessable folder. Now this is the part that took nearly 3 days to figure out in order for the program to recognize and load an image to it you have to put the device in "recovery mode". You might ask well how do I do this, as every forum out there just says put in recovery mode and it will work, BUT HOW you still ask. The internet won\'t tell you, the company won\'t tell you, hell even other people on forums won\'t tell you. But alas I shall.
RECOVERY MODE Proscan PLT8031
Simply plug in your usb cable to your computer, then while holding your menu button, to clairify as I don\'t know the exact name of the button, it\'s the one to the left of the home button. plug in the usb cord to the device while still holding that button. Do not let go of the button until you see that windows has detected your hardware and is looking for a driver.
FYI windows usually will not find a driver, I have included links to the drivers you will need.Now if your at all used to device manager you should know how to point it to the driver you need. It will be called "rockusb.inf".
Once this is installed then open and run "RKBatchToolv1.4" as administrator. You then need to click the three dots in the top right to locate and load the "update.img" file. Make sure at this point that your device is recognized with a "green square" near the bottom of the window.
If all that checks out click the upgrade/restore button. To be clear it\'s one or the other, not both, technically didn\'t see a difference between them. This process will then start and will take between 5 to 10 minutes. DO NOT TOUCH ANYTHING. if you unplug your device too soon you will have a nice paper weight instead of a tablet. Wait untill it is completely booted into the setup your android device screen before closing the rkbatchtool and safely disconnecting the device.
Congrats on your newly rooted/recovered plt8031 tablet.
29RockUSB Driver - http://uploading.com/2ca29934/29Rockusb-zip
http://www.generalfiles.com/download/gs5a611f4bhci0/29Rockusb.zip.html
http://rapidlibrary.com/files/29rockusb-zip_ulcqxffyzwieon.html
If none of these work for you just google "29RockUSB" without quotes.
Firmware (update.img) - http://www.proscanvideo.com/tech-help/PLT8031.asp
RKBatchToolv1.4 - http://www.filecrop.com/RKBatchTool-1.4.rar.html
http://www.x-drivers.com/catalog/flash/tablets/companies/fuzhou_rockchips_electronics/models/rk_batch_tool/27575.html
