Question about Fargo HDP5000 Thermal Printer
MY PRINTER REMAINS ON INITIALIZING
It does not start properly and does not allow me to print, it stays on initializing.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Fargo Master
  • 1,363 Answers
Is this an HP 500 or 600 ?
the fuser is going bad it will need replacing.
Posted on Jan 06, 2017
6ya staff
SOURCE:
2800 HP business inkjet won't stop initializing after installing print heads
BECAUSE IT CANNOT FIND THE PROPER HARDWARE AND INK. TRY TO PRINT A TEST PAGE, AS WHEN YOU FIRST TEST IT.
Jun 18, 2015 | HP Business InkJet 2800 Printer
Why am I getting the error code 22550
It would be helpful to know the exact model number of your printer and the software level. If this is a PW300, it is an Initialization Error. Something is out of place that is not allowing the printer to start up properly. Opening and closing the lids may temporarily solve the issue but if it keeps on returning without having jams, there is either a sensor problem or the code level may need to get upgraded. New code levels have fixes that prevent false jam indications.
Jun 24, 2014 | OCE Check Plot Bond Paper, 20 lbs., 34" x...
Fail to initializing
The fail to initialize is typically a problem with the document scanner...but not always. here is a quick test you can try. Turn the unit off then power it on again. Slightly lift the copy lid as the unit goes through warm up mode...pay attention to the light color emitting form the scammer. it starts to blink red, then changes to a bright white IF the scanner is working properly. IF the scanner is NOT working properly the scanner stays RED during the warm up.
Nov 26, 2013 | HP LaserJet Pro M1212nf MFP -...
I have a 2002 gmc sierra 2500hd 6.6 diesel the trucks eng. cranks but dose not start, but if i spray starter fluid into the air filter it starts and stays runing good with no problems, but every time i...
Check to ensure your glow plugs are functioning properly.
Is the truck blowing a lot of white smoke during idle or initial start up? If so, you most likely have injectors that are not performing correctly, not allowing vehicle to start.
Russ
Mar 20, 2011 | 2002 GMC Sierra 2500HD
I have a Xerox 8560MFP printer with the following error code. 07010.43:39050 Any help would be appreciated
Your print head is stuck. Either the print head block has gotten ink in it and will not allow it to tilt, or the print head wiper is tacked, ( stuck) to the print head not allowing it to move properly.
Jan 11, 2010 | Xerox Phaser 8560MFP Laser Printer
HP 4600 Color Printer stays in "Initialize" Mode
If you are using a jetdirect network card it could be the cause of your problem. Pull the network card and restart the machine. Seen it a couple of times
Jul 25, 2009 | HP LaserJet 4600dn Color Printer
Sharp electronic cash register XE-A203 - keeps printing receipt
I don't have this particular cash register, But I took a look at the manual and I recommend the following:
A. Turn the cash register off.
B. Unplug it.
C. Remove the batteries.
D. Wait at least five minutes.
E. Initialize the cash register. This procedure was copied from thwe manual:
In order to operate the cash register properly, you must initialize it before operating for the first time. Follow this
procedure.
1. Insert the manager (MA) key into the mode switch and turn it to the REG position.
2. Insert the plug of the AC power cord into the AC outlet. The buzzer will sound
three times.
IMPORTANT: This operation must be performed without batteries installed.
3.
The cash register has now been initialized. The register display will show
"0.00" and then “NO BATTERY”.
If the buzzer does not sound when the plug is inserted, the initialization has not been done
successfully. (This will occur when the voltage is high because you operated the cash register
before starting initialization.) Wait at least one minute after pulling out the plug and insert the plug
again.
F. Download trhe manual from here:
http://www.ormsson.is/skjol//skrifstofutaeki/xe-a203,213,303_manual.pdf
And proceed to program your sales tax (or VAT), departments, clerks, etc.
Jan 25, 2009 | Office Equipment & Supplies
Ink system has failed. Unable to print. Error:0xc18a0301. Turn power off then on again. Problem continues. Hp Photosmart C5180 All-In-One
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Nov 13, 2008 | HP Office Equipment & Supplies
Black ink not working; but colors are
press menu then start mono (blue copy button) then fourtimes arrow up (tel index). machine will be in maintenance mode. press 7 then 6 then 4 then start mono. machine will initialize the carts and do some cleaning cycles.
If you're outside can/us: after that press zero then nine. machine prints test print. If youre inside leave maintenance mode and run a test print manually.
if you cant see any bk the ph is clogged and cant be fixed anymore (because of wrong ink: pigmented ink will clogg the filter infront of the nozzels; use ONLY dye-ink for all colors!)
leaving the maintenance mode by pressing 9 then 9.
Nov 27, 2007 | Brother MFC 210C All-In-One InkJet Printer
Fargo HDP5000 Thermal Printer Logo
335 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Altin S1
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
