hello there"
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven
temperature probe (aka oven temperature sensor) terminals at the EOC
(electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are
different - check the wire harness between the oven temperature probe
and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
- The part number for the oven temperature probe is
AP3704441
- The part number for the EOC is
AP3776874
- The part number for the EOC overlay is
AP3778486
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html#ixzz156CO7RjB
