Saw starts fine and cuts for about 20 minutes. Then it starts to sputter and stops. I can restart and idle but won't run when I press accelerator. I have changed the plug, fuel filter and air filter.
Two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
I have had the same problem. Mine was vapor lock. If your is vapor lock it probably wouldn't be too easy to start unless you open the fuel cap and let it depressurize. The husqys have a fuel tank vent where the fuel lines enter the tank. It is very possible for these to clog and not vent properly.
My saw acts the same. The carb has been replaced with no change in performance. My saw is the 350 with the 18 inch bar.
