40" tv smart tv
You don't indicate model number or age of your samsung tv, although it's very likely you may find swollen tops on one or more electrolytic capacitors on the power/inverter module. The tops of the caps may bulge like those i've pictured. You will need soldering skills to replace these parts. Value and polarity are very important while replacing electrolytics.
SOURCE: For the last few days, my Samsung 40" LCD tv
the problem with ur tv is the main board , u can call samsung and get the later fireware version or u going to have to replace the main board of ur tv
SOURCE: taken delivery of 40" samsung
Make sure you have it set to wireless off in the menu or it will not recognise the ethernet port on the back even if it is flashing. Most tvs with browsers come with the wirless function set to on. Also if it has search for internet signal you could try this to get it to rec. as well.
