The gold piece for the number 7 came off and is floating inside the crystal. It has 2 small pins on the backside that fit into the watch face.
SOURCE: Caravelle by Bulova watch strap adjust
You need to push the pins out in the direction of the arrows. Then take out one link from each side. Put the pins back in the same way they came out, with the slot pointing the same direction as before.
SOURCE: How do I remove the back of my Caravelle by Bulova
There is a special gear type tool with prongs on it that rotate the back of the watch off (turn to left to take off, right to replace). If you don't have one, take the watch in to a jeweler's and they will replace the battery for little or nothing, usually.
Good luck, and hope this helps.
SOURCE: Today is Tuesday, March 8.
do not pull the stem all the way just half way out. Turn clock wises the date should move. move to correct date. counter clock wises for the day. For the analog hold down the set mode button until it starts to blinking to change number with the start and stop. to change what is blinking press the mode button
