Question about Riccar Vacuums
How to take apart riccar model stine.1
The engine smells hot and I know the kids missed putting a bag in one time. Also, we never knew about the 2nd filter until my son tried to take it apart. Bad salesman right there!! We need to get into the motor compartment to super clean it.
6ya staff
SOURCE:
Anonymous
SOURCE: Won't start.
There is a reset button at the back of the powerhead. The user manual can be downloaded from the electrolux website, although I didn't find it very useful. There was some info on how to change the powerhead drive belt.
Posted on Jan 08, 2008
Anonymous
SOURCE: model 116 hose clog?
https://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Model 116 hose clog?
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 24, 2008
Anonymous
SOURCE: burning smell
I had burning smell and some visible smoke which I tracked down to the handle area. The mains socket at the bottom of the handle had burned out. When I pulled the plug out I noticed that the prongs were blackened and scorched. I will replace the socket.
Posted on Jan 05, 2009
David Shaub
  • 2976 Answers
SOURCE: burning smell kenmore canister
Any reputable vacuum cleaner repair shop can check it for you. It will have to be a multi brand shop, nit a Kirby, or Electrolux thpe. They are dealers and only repair their own brand.
Posted on Mar 04, 2009
jamesvera
  • 52 Answers
SOURCE: Opening Miele S28i Vacuum cleaner
If it is similiar to the white star you may find the instructions here useful: http://www.sannerud.com/house/miele.html
hope so
Posted on Aug 19, 2010
I purchased a riccar 2150L second hand with no information. I have a 10yr old riccar supralite and love it! But the 2150L looks older. I am curious what the age of riccar 2150L vacuum is.
Your m
2150 L is likely 25 to 30 years old. The first Riccar vacuums were made in Japan. Your was likely made in Taiwan. Production of most models was brought to St. James, MO 20 years ago. Filters, bags and some parts are still available from your local Riccar dealer, or from ThatVacGuy.com
Dec 14, 2017 | Riccar Vacuums
My Riccar vacuum was working but then just stopped and won't turn on. I changed the bag even. What's up?
Hi Patty.
Could be:
Power cord. Check esp. strain-relief where cord enters housing.
On/off power switch. Needs strip down & continuity check.
Motor burnt out. Smell if burnt. Strip search.
Carbon brushes inside motor worn. Dismantle & check / renew.
Does this help?
Regards, Clive.
Nov 05, 2017 | Riccar Vacuums
Riccar 8995 no suction
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
May 18, 2014 | Riccar Vacuums
Riccar 8850 red light is on and won't go off, I changed the bag but do not know what the light indicates
The light indicates a restriction, a full bag or clog or something restricting the airflow
Dec 15, 2013 | Riccar Vacuums
After changing the bag on my riccar it is very hard to push'
after putting a clean bag into the vacuum cleaner, more air can get through it, so it generates more vacuum, sp it is obvious, that it will be harder to push for some time. if it wont get better, it only means you didnt gt it with a clean airbag
Apr 22, 2013 | Riccar 8955 Upright Vacuum
The switch to my Riccar 1500p hose is broken for the 2nd time. I don't want to replace the entire hose again, where can i get the switch and leads?
Take the screws out to take the handle apart. Remove the switch and take it to your hardware or local vacuum to to get the correct replacement.
Apr 03, 2013 | Riccar 1500 Simplicity S24 And S20...
Where can I get replacement wheels?
Greetings from GoVacuum.com,
I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at chris.jones@govacuum.com.
We do stock a lot of parts for your 4812 Riccar, including the following;
Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
http://www.govacuum.com/ricc103.html
Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
http://www.govacuum.com/ricc117.html
Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
http://www.govacuum.com/ricc112.html
Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
http://www.govacuum.com/ricc133.html
I look forward to helping you if you still need to get the wheels for your vacuum.
Thank you,
Chris J.
GoVacuum.com
Jan 11, 2010 | Riccar 4812 Vacuum
How do I find the opening to change the bag on the Riccar RC 1100
Just above the hole where the hose goes there's a squarish part to where your hand should go. It should just pull upwards.
User manual download (FREE and in pdf form:)
http://www.riccar.com/ftp/whitepapers/1100_OwnersManual.pdf
Jun 17, 2009 | Riccar RC1100 Compact Vacuum
Lost suction after I changed the bag and cleaned the air filter
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
May 20, 2009 | Riccar 8955 Upright Vacuum
Burning smell
Nov 02, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
110 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
rebecca curry
quennie732
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
