In most cases, Microsoft Word is trying to find the dll's that are associated to it to open the program. In order to resolve this issue.
Open start or windows logo, settings or control panel, control panel in windows xp, open add/remove programs in windows xp or program features in windows vista or windows 7. Scroll down to Microsoft Office 2002 and click on add/remove. When you do this there will be an option to repair. Click repair. From here it will diagnose which files are not correctly associated and will attempt to repair those broken links.
Once the repair is complete you should be able to open Microsoft Word with no problems.
Extra info:
Windows updates can also be a culprit in these issues. Installing add-ons that should not be enabled in Microsoft Word until you are in the actual application.
if you cannot resolve the issue that way, you can open the run command and type winword /a or /s these are safe mode features built into Microsoft Word to disable add-ons.
This is the instructions on how to remove existing ESS system in order for you to start on a fresh.
Please follow the instructions:
Uninstall Easy Share software:
Select Start > Settings > Control Panel > Add / Remove Programs. For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
Select Kodak Easy Share software.
Select Remove (or select Change, and then select Remove).
Run the Clear utility:
Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
Click the Download button, and then follow the on-screen prompts.
After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Please reinstall your version of Easy Share software:
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If you suspect it could be directly related to your software.
You need to follow the instructions:
You need to upgrade your version to be compatible with Windows Vista: Please do a Clean Install on the software:
If this fault message is on your computer starting Easy Share Software: Please do a Clean Install on the software:
This is the problem caused by your Kodak easy share software. All you need is to reinstall the Kodak easy share software, using the orginal cd that you got with your kodak camera. But Before you do remove the old software from your computer.
Windows Vista:
Click Start / control pannel / Programs and features. and look for kodak and remove it.
Windows XP:
Click start / Control Pannel / add and remove programs.
Please rate this solution very high if this was a helpful information.
Last options that you can do is to reinstall the Software.
First check the compatability of Easyshare, Right Click the icon on your desktop and click compatability tab, then remove all check marks under that tab.
Remove the Easyshare Software from the Control Panel, Add Remove programs
Then Run the clear utility software from the web at this site www.kodak.com/go/clear
After that restart the PC
