SOURCE: KDP-51WS655 OR KDP-57WS655 57 inch HD PROJECTION
check the power switch for dry joints and resolder all joints if it still doesnt work check power board for dry joints as this is a common problem let me know how u go
SOURCE: my sony wega 50 inch tv the standyby light is
You need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
SOURCE: I need to download a
You can download and print the instruction manual in PDF format by clicking this link
To download Quick setup guide, click here
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
SOURCE: sony wega model No. kdp-57ws655
Hi:
This is a problem with the D-Board, or deflection board as we call it, there are two Ic's that needs replacing that has failed. They are power controller Ic's on the deflection board.
SOURCE: Part Numbers for Q8013, Q8014, R8051, IC8005
Q8013 & Q8014 are both 2SK3568 sony Part# 6-550-882-01R8051 is 0.1 1/2 watt fusible resistor sony Part # 1-216-837-11 and IC8005 is a TL1431CZ-AP sony Part # 8-759-586-17 you should be able to get those parts through www.tvrepairworld.com
