Question about Roper RAS8445KQ Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
The washer will fill with water but won't go into wash cycle...emptied washer and spin cycle makes a humming noise
  • Anonymous Mar 15, 2014
    washer will fill but wash cycle does not work
It will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Posted on Feb 21, 2009
    New Friend:
My washer, frigidaire stops at the spin dry cycle. Even after manually turning the timer the spin dry or pump wont work. Spinning back to the normal wash cycle it works. Checked the pump directly connecting the leads in 220 volt and it works fine. Possibly, I doubt the timer problem. But at the spin cycle the time clicks and stops. Maybe the timer motor doesnt respond at the spin cycle. I tried opening the timer and found the cam inside is okay. Am not sure if the cam has worn out cud be the reason the cam track work out. Any suggestion please help how to check the timer circuit continuity.
Posted on Jan 06, 2013
2 Suggested Answers
6ya staff
SOURCE:
GodBlessU
Aparajita Batabyal
  • 3513 Answers
SOURCE: washer makes a loud noise
Hi
As per your description it sounds like the motor drive coupler has failed. If the drive coupler fails you will hear the motor running but nothing will happen except water will pump out. Tilt the front of the washer up a couple of inches & look on the floor for rubber shavings or broken plastic pieces, this will be a sign that the drive coupler has failed. If the motor is seized up I recommend checking the pump. If something is lodged in the pump the motor will just hum. Other possibilities; motor, timer, transmission or harness problems. So tilt the washer to the back and look closely to the motor, the coupling from motor to trans may be broken. The motor drives the agitator, using a belt or a drive shaft. It is possible that the drive belt is broken too.
Please check this link bellow for more information which will help you troubleshoot your problem:-
http://www.washerhelp.co.uk/diy-repair-help_2.html#cl_q4
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
Posted on Aug 26, 2011
Washer will only fill slightly on rinse cycle and not at all on wash cycle
Is the water on? Does the pump run when emptying machine? If yes to both, try running the machine through a spin cycle if you can and let it finish on its own. The valve should close and allow it to fill. Also, top or front load washer? ... These may help How to Fix Washing Machine That Won Fill With Water DoItYourself com
Jul 17, 2018 | Washing Machines
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
We put a heavy blanket in the washer and the load stopped suddenly with a washer full of water. It wouldn't spin or empty and made a weak sound but nothing worked. We had to manually empty the water....
Usually that means the drive belt is loose and slipping. You should be able to tighten or replace the belt.
To test the belt you have to remove the washer back.
Jul 29, 2011 | Kenmore Washing Machines
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Roper RAS8445KQ Top Load Washer Logo
3,432 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Gerry Harvey
Gerry Harvey
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
