Either the system is in valet or, the chirps have been deleted or, the siren is broken.
If the LED is on solid the system is in valet. open the door, press lock, unlock, lock on the remote to remove valet.
Press and hold the lock button. This activates the car finder/panic. The siren should begin to wail. If it does, the siren works. If it doesn't and all you see is the aprking lights flashing the siren is defective.
SOURCE: viper 5701 led light does not flash when armed, stays lit when alarm is disarmed
If the LED is on solid then the alarm is in valet. To exit valet, press "F" twice then press unlock on the remote. The LED should turn off.
OR,
enter the vehicle, turn the ignition on then off, press and release the valet/programming button on the antenna. LED should turn off
SOURCE: viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
SOURCE: when i arm the car how can i hear the sound viper on
whats the make and model fo the alarm? and go to viper.com/support for more information
SOURCE: my viper 2 way pager remote will not arm or disarm
It could be set on car #2. Press function for 8 seconds and a light next to lock should come on. If the light next to unlock and lock (two lights) then it is set to #2 car (you can operate 2 cars with one remote). All you have to do is press function again to toggle between the two cars. You want to end up with only one light showing.
So, hold function for 8 seconds, then after a light shows, release and press function until you only see the one light.
