It is good to take home pregnancy test in the morning, try not to get up and go to the bathroom during the night and then do the test as soon as you get up..
It\'s best to use the
first urine of the morning to take a pregnancy test with as it\'s the most
concentrated and HCG levels will be higher but it\'s also ok to do it at other
times of the day.
There are many pharmacies that sell twin packs of pregnancy
tests. Try this one http://www.boots.com/en/First-Response-Early-Result-Twin-Pregnancy-Test-2-Pack_1785/
Or
The results are stained onto the test, so even though they
may fade a little over time, the results will stay as they are. If you got a
positive pregnancy test result - then you are pregnant.
If you got a positive result in the result window then you
can consider yourself pregnant no matter how light or dark the line is.
It's hard to tell you exactly what that means as it could be that you are
pregnant but your HCG levels were too low to trigger the line within the time
frame but it could also just be a fault in the test. I would wait a couple of
days and then try another one.
