Not all
pregnancy tests are the same but there are usually two ways of getting a
positive result:
1) Some tests just show a clear vertical
line in the control window and if you are pregnant you will also get a clear
vertical line in the result window.
2) Some tests show a vertical line in
the control window and a "-" sign in the result window if you are not pregnant
and a "+" sign in the result window if you are.
All pregnancy tests come with instructions and usually they have pictures explaining the results. You can probably hold your pregnancy test alongside the leaflet if you are confused and it should clarify the result for you.
