Question about Health & Beauty
What is a color changing tip on a pregnancy test? Is that where you get the result?
    New Friend:
  • 49 Answers
A color changing tip that comes with some of the more expensive home pregnancy tests is just an extra way of showing the user that the test is actually working. The actual result of the test appears in the result window - you have to read the specific instructions to be fully sure how a positive result will appear on that particular test.
Posted on Mar 04, 2013
6ya staff
SOURCE:
Is it ok to use an out of date pregnancy test? Mine went out of date 2 months ago.
Pregnancy tests contain chemicals that interact with the HCG chemical that they are testing for. If the pregnancy test is out of date, it might affect the accuracy of the results. You should dispose of it and buy a new one.
Mar 04, 2013 | Health & Beauty
Do pregnancy tests check for any abnormalities?
No, basic pregnancy tests simply check whether you are pregnant or not. They don't give any other information about the fetus. For this you need to do scans and more detailed testing through your doctor.
Will the result of my pregnancy test change after time? If it was positive and then fades, does that mean that I am not pregnant?
The results are stained onto the test, so even though they may fade a little over time, the results will stay as they are. If you got a positive pregnancy test result - then you are pregnant.
How do I read the result of my pregnancy test? I am getting so stressed about it that I just cant understand the instructions.
Not all pregnancy tests are the same but there are usually two ways of getting a positive result:
1) Some tests just show a clear vertical line in the control window and if you are pregnant you will also get a clear vertical line in the result window.
2) Some tests show a vertical line in the control window and a "-" sign in the result window if you are not pregnant and a "+" sign in the result window if you are.
All pregnancy tests come with instructions and usually they have pictures explaining the results. You can probably hold your pregnancy test alongside the leaflet if you are confused and it should clarify the result for you.
I did not get a line in the control window of my pregnancy test. Why did it not work properly?
There are a
few reasons why your pregnancy test may not have worked properly. Perhaps it\'s
just a faulty test or you may not have applied enough urine to the tip or
possibly too much urine and it flooded the test. Sometimes not laying the test
flat after the urine was applied can affect the results.
How long do you have to wait for a home pregnancy test to give a result?
Most home
pregnancy tests give a final result within 2 minutes of coming into proper
contact with the urine flow.
Can I take a pregnancy test before I have even missed my period?
You can buy
pregnancy tests that are super sensitive and claim to detect pregnancy within 7
days of fertilization but you are more likely to get an accurate result if you
wait longer. Once you have missed your period, you can take a pregnancy test
and it will be easier to detect HCG levels in your urine if you are actually
pregnant.
How reliable are home pregnancy tests? I got a negative result but I keep thinking it might just have been a bad test.
Don't worry - if you got a negative result, the chances are that you are not pregnant. Home pregnancy tests are about 97%-98% reliable. But if you are still really worried, go and see your doctor.
Is it worth buying a home pregnancy test? How do they work?
Home pregnancy tests are actually quite reliable. They work by detecting
the hormone HCG which is found in both urine and blood. If you have a lab blood
test, it will probably detect pregnancy earlier than a home urine test.
Health & Beauty Logo
78 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
