It is a kind of quiz. Where you have give answers for all the questions. Based on your answers they will give the result.
Online
pregnancy tests are sites that offer a software where you input all your data
such as physical health parameters etc and they then calculate the likelihood
of you being pregnant. Whilst they may be able to predict a pregnancy, there is
no substitute for a HCG hormone detection test either via a home pregnancy test
or at the doctor.
Pregnancy tests contain chemicals that interact with the HCG chemical that they are testing for. If the pregnancy test is out of date, it might affect the accuracy of the results. You should dispose of it and buy a new one.
There are certain brands of home pregnancy tests that can
detect the HCG hormone which is present in pregnancy at very low levels. If
it's listed on the packet, try and buy a brand that says it can detect from
20mIU/ml. Some tests are more sensitive to early pregnancies than others, but
don't worry, most pregnancy tests are reliable and accurate up to between 97%
and 98%.
No, basic pregnancy tests simply check whether you are
pregnant or not. They don't give any other information about the fetus. For
this you need to do scans and more detailed testing through your doctor.
Not all
pregnancy tests are the same but there are usually two ways of getting a
positive result:
1) Some tests just show a clear vertical
line in the control window and if you are pregnant you will also get a clear
vertical line in the result window.
2) Some tests show a vertical line in
the control window and a "-" sign in the result window if you are not pregnant
and a "+" sign in the result window if you are.
All pregnancy tests come with instructions and usually they have pictures explaining the results. You can probably hold your pregnancy test alongside the leaflet if you are confused and it should clarify the result for you.
