Rebuild parts for a light engine. Where can you find them?
Ken
The problem is you can't. You will probably spend more time and money replacing parts than replacing the entire engine.
Im looking for parts and info also on rebuilding light engines. ive searched endlessly. found a little info on how to rebuild the projection lamps but havent located a source for the actual bulb inside the glass reflector. it metal halide and runs about 85 volts.sylvania 54112 looks interesting as a possibility. good luck searching. this info is a well kept secret. thanks mike
i need to know where go and place the 4 lenes in a wd73737 engine light
