Left side of screen is stretched. Right side has proper aspect ratio
SOURCE: vertical bars both sides of screen visable with white background
do thy get lighter going from left to right? prob bad scan filter in hv. need tech unless your very handy.
SOURCE: my sony tv problem is that the picture is stretch horizontally..
If you have a DVR too, there is a pound (#) button on the beside the zero on the DVR remote that stretches my screen off and on. Try that.
Turn on your VIZIO HDTV. Press the orange button with the "VIZIO" logo, which looks like a letter "V" with a triangular wedge in the center. If there is no VIZIO logo button, press the "Menu" button. Press the "Right Arrow" button twice to highlight the "Setup" icon, which looks like a wrench.
Press the "Down Arrow" button three times to highlight the "Wide" menu item. Press the "Left Arrow" or "Right Arrow" buttons repeatedly until the correct aspect ratio is selected. "Normal" is for a standard definition 480i signal, which has a 3:4 aspect ratio. "Wide" is for high definition signals, and has a 16:9 aspect ratio. "Panoramic" stretches the outside of the image while keeping the center at the normal aspect ratio. "Zoom" enlarges the image on the screen. Press the "Last" button twice to close the VIZIO on-screen menu.
Watch the image on the screen of your VIZIO HDTV to ensure that the picture is at the right aspect ratio. If it still looks distorted, it's most likely because you chose the wrong aspect ratio setting, because your source device is set incorrectly or because you used the wrong connection method.
