Question about Apple MacBook Air
Mac bok air startup almost full - Apple MacBook Air
How to fix a slow Mac? My MacBook is getting slow recently, how to speed up it?
there are many reasons about why your Mac works slowly. you should firstly clean it up. here is article which talks about how to speed a Mac you may need: 11 Methods to Speed up Your Mac
Jun 25, 2015 | Apple MacBook Air
How can I turn off startup sound
StartUp sound is good for your system because it will tell you something but if you want to turn it off then try to
press the F10 key on your keyboard to mute you Mac before rebooting or use any app for it. if you want to know the importance of startup sound than follow Apple Support Number .
Jul 15, 2014 | Apple MacBook Air
Why is my macbook air a1466 showin a file with a question mark when i turn it on and how do i fix it
http://support.apple.com/kb/ts1440
A flashing question mark appears when you start your Mac Symptoms
If you see a flashing question mark when you start your Mac, it's probably because it can't find the system software it needs to start up. Usually, all you have to do to get your Mac back up and running is remind it where its software is.
Resolution
If your computer starts up normally after a brief delay, you probably just need to reselect the startup disk in Startup Disk preferences. It's normal to see the flashing question mark when a startup disk has not been selected. In most cases, reselecting the startup disk is all that is required to resolve the issue.
Sometimes, your computer may not start beyond the flashing question mark.
Tip: If your computer has a gray screen (with no flashing question mark) startup issue, see Mac OS X: Gray screen appears during startup.
Check the mouse and keyboard
This issue might occur if a mouse or trackpad button is pressed during startup. Make sure the button isn't pressed.
If the issue persists, shut down your Mac with its power button, disconnect any external mouse and keyboard, then turn on your Mac with its power button. If the flashing question mark issue persists, reconnect the keyboard and mouse.
Additional steps
If your Mac still starts to a flashing question mark, follow the steps below. If any step resolves the issue, you don't need to continue to the next one.
  1. Select your Mac OS X startup disk with Startup Manager by restarting and holding the Option key. After your Mac starts up, restart again to verify that the flashing question mark does not appear.
  2. If the issue persists, insert your Mac OS X installation disc. Be sure to either use the disc that came with your Mac, or, if you installed a later Mac OS X version from disc, use the newer disc.
    MacBook Air note: On a MacBook Air, there are two options for starting up from Mac OS X media: Either connect a MacBook Air SuperDrive to the MacBook Air via the USB port and restart the computer, holding down the C key during startup, or use Remote Install Mac OS X to startup from a system software DVD that's located on a partner computer. Once started up from Mac OS X media, skip to step 3.
  3. Restart the computer, then hold the C key during startup.
  4. From the Utilities menu, choose Disk Utility. Don't click Continue.
  5. Select your Mac OS X disk (named "Macintosh HD" by default) in the left side of the Disk Utility window.
  6. Click the First Aid tab.
  7. Click Repair Disk to verify and repair any issues with your Mac OS X startup disk.
  8. After repairing the disk, try to start up normally.
    Important: If Disk Utility finds issues it cannot repair, you may need to back up as much of your data as possible (or use Time Machine to back up to a different disk), then erase the disk and reinstall Mac OS X. You should back up important files and data before erasing a drive. Erasing deletes everything on the hard disk (including things on your desktop). Also, you can install Mac OS X onto an external disk, start from the external disk, and use Migration Assistant to transfer items from your usual internal Mac OS X startup disk to the external disk, then erase the internal disk and reinstall Mac OS X.
  9. If the issue persists, and Disk Utility didn't find any irreparable issues, quit Disk Utility, quit the Installer, select your disk when prompted, and restart.
  10. If the issue continues, reset PRAM. Note: After resetting PRAM, if the computer starts up normally, reselect the startup disk in the Startup Disk preferences.
  11. If none of these steps resolve the issue, start up from the Mac OS X Installation disc and reinstall Mac OS X.
Last
Mar 30, 2014 | Computers & Internet
How di I reset theApple Mac Air to factory settings
Do you have the original Mac OS X Install DVD? Just pop that in, restart the MacBook Air, just after you hear the "dong" sound on startup with the white screen, immediately press an hold down your Control key (I think it is) an you will get a select menu of what you want to boot into like on Windows, select your Mac OS X DVD an everything else is pretty much self explainatory from there to have everything back to factory default as if you just bought the MacBook.
(: hope this helps mate.
Nov 08, 2013 | Apple MacBook Air Mac Notebook
Hi,\r\ni have a problem with my macbook air when
Try restarting your computer while holding down the X key. This may force the computer to start up using your Mac OS X system. If it does, release the X key, then open System Preferences and click Startup Disk. Make sure your Mac OS X system is selected. If you are unable to start up using the X key, restart your computer and immediately press and hold the Option key. Release the Option key when icons start to appear in the center of the screen. Select the Mac OS X system disk, then click the forward arrow to continue starting up.
If the above attempts to reselect your Mac OS X startup volume are unsuccessful, try resetting PRAM. Shut down your computer, then turn on the computer and immediately press and hold Command-Option-P-R until you hear the startup sound for the second time. Open System Preferences, click Startup Disk, and select your Mac OS X volume.
Hope this helps. If none of these options fix your problem, bring your computer to an Apple store, they are always very helpful and almost never fail to fix the problem!
Mar 11, 2011 | Apple MacBook Air
Mac book starts with blue screen startup disk full
your disk partition is having problem.if u have not taken backup then boot the system with FW mode with saperate Laptop and backup the data,then repartition the hdd and install freshly
Apr 17, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
The printer wont work with my Apple Mac Bok
Thats because there is no support for a Dell 922 with any Apple/Mac products
Jan 17, 2009 | Dell 922 All-In-One InkJet Printer
Full Memory
There are 2 ways you can fix this.
1. Upon Startup, hold "apple" key, option key, "P" and "R"
Hold them until you hear it chime 3 times then release. This will reset the parameters, and do the apple version of a defrag, only takes about 5 mins though.
2. Start up and hold "shfit" key. Hold until apple logo and spinning wheel show up, then release. It will perform a mini "permission repair" Once Mac has booted up fully. Restart.
This should solve your problems.
Mar 17, 2008 | Apple iMac G5 Desktop
Apple MacBook Air Logo
32 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
