Question about MSI K8MM-V Motherboard
Power LED and other connection diagram for MSI 7142 motherboard
Correctly connection peripherals and wiring the power LED/ power switch etc
  • MSI Master
  • 5,660 Answers
MSI Support > K8MM-V motherboard (ms-7142) > Main Support page,
http://www.msi.com/product/mb/K8MM-V.html
Hover your mouse cursor on the Download tab.
(Overview / Specifications / Download / Support / etc)
In the drop down list click on - Manual
Underneath the Download subheading click on the blue -
M7142v.1.0.zip (2005-09-07)
Click on the 'country' name nearest yours.
(U.S. is a country. Europe and Asia are continents)
A small window will come up -
Opening M7142v1.0.zip
Make SURE the small circle to the left of Save File, has a Green dot in it.
IF not; click in the small empty circle to the left of Save File.
Now go below in the small window, and click on - OK.
A small download window will come up.
Allow the file to fully download, then DOUBLE-click right on the file name. ( M7142v1.0.zip)
In the next small window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows, click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name.
(Next to the red Adobe PDF icon)
There is the motherboard manual in PDF file form.
The Adobe Reader page number box is at the Top, to the right of the Down Arrow.
You can go page by page, to the page you want, using the Down Arrow; or if you know the page you want you can do this,
1) Put your mouse cursor in the page number box at top.
Left-click once. Anything in the page number box, is now highlighted in blue.
2) Type the page number.
3) Press the Enter key.
A) Go to Page 5 - Layout.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
On your motherboard there are two.
JFP1 and JFP2.
Junction Front Panel 1 and Junction Front Panel 2.
JFP1 is on the Right side of the motherboard, down in the Bottom/Right corner.
It sits Vertically on the motherboard.
Two columns of contact pins.
5 on the Left side, 4 on the Right side.
Go to Page 14 - Front Panel Connectors: JFP1/JFP2
The pins on the Left side are numbered ODD.
The pins on the Right side are numbered EVEN.
Starting on the Top/Left side, coming down;
Pins 1, 3, 5, 7 and 9.
Starting on the Top/Right side coming down;
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
This is reserved for the factory. Believe it is a 5 Volt (DC) test point.
D) Pins 2 and 4 are for the Power On LED light.
It is for a TWO wire Power On LED light.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10.
The JFP2 header is to the Left of JFP1.
It is situated Horizontally, and close to the bottom of the motherboard.
Two rows of pins.
3 pins on the Top row, 4 pins on the Bottom row.
The Top row is numbered ODD.
The Bottom row is numbered EVEN.
Starting on the Right side, going towards the Left; Top row,
Pins 1, 3, and 5. There is NO Pin 7.
Starting on the Right side, going towards the Left; Bottom row,
A) Pins 1, 3, and 5 are for a THREE wire Power On LED light.
I assume Pin 1 is for the Negative wire ( - ), and Pins 2 and 3 are for the two Positive wires.
It's for a dual color Power On LED light.
Example: Turbo Mode has a Green light, Normal Mode has a Yellow light.
B) Pins 2, 4, 6, and 8 are for an internal speaker.
Internal speaker is used to hear the BIOS Beep Codes.
For additional questions please post in a Comment.
[Thought you may want the motherboard manual, too]
Regards,
joecoolvette
Posted on Mar 04, 2013
6ya staff
SOURCE:
aceltix
andi n.
  • 119 Answers
SOURCE: MS-6378 ver 2 Motherboard fitted to my Time Computer
here it is your manual man
http://asia.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=283
msi site your board/the manual..youll have there at the beginning the diagram of wires and pins..
I have a MSI too..great boards man..great boards..
fixya:)
bye
Posted on Feb 08, 2008
Anonymous
SOURCE: pls help for downloadin via vt8237r audio driver for msi 7142 motherboar and amd processor
pls help me to download vt8237 plus audio driver / that msi m/b driver...pls urgent...
Posted on Sep 20, 2008
Anonymous
  • 56 Answers
SOURCE: Connection Diagram for MSI N1996 motherboard
GOTO MANICATURE WEB SITE TECHN SUPPORT MOTHERBOARD LAYOUT DIAGRAMS
TRY MOTHERBOARD.ORG
IM PRETTY SURE THAT MSI DOES HAVE A WEB SITE ON THE INTERNET
CANDYMANGANDY
Posted on Jan 27, 2009
Anonymous
SOURCE: I'm looking for power connetion diagram for a MSI N1996 MB
You have an MSI 6390* motherboard, MSI has an archives with 3 different versions of manuals available, just depends on which version of the board you have.
Here's a link:
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=307
Posted on Jun 03, 2009
Anonymous
SOURCE: i have a msi motherboard (ms-7142) with built-in souncard. i dnt
i not able to download audio diver for MSI ms7142 VER:1
Posted on Jun 13, 2009
I got a mother board from a friend it a k9n6sgm-v but i can find where i have to connect my speaker-HDD LED my rest switch all the front panel
http://www.msi.com/service/download/manual-4593.html
If you follow the above link, you can download a pdf of the manual. On page 7 at the bottom you will find a diagram showing where to plug in speaker, power LED, HDD LED, reset switch etc.
Aug 16, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Need wiring diagram for ms-7142 motherboard... fixing a friend's computer, but they unplugged the wires that run to the front... therefore the power and LEDs don't work...
The connector bus where the front wire connections go, is usually marked. It's usually two rows of pins sticking up. You should be able to determine where the power wires connect. One pin will say PWR. The second pin you need is either next to, or across from that pin. The LED pins are labled too. Keep in mind that LED's have polarity. That is, a diode [light emitting DIODE- LED] only works one way. It's a one way "Valve" for electricity. So if you determine which two pins are for the power light and you connect them, it still may not work. Just reverse the two wires to the two pins and it should work.
I can't imagine that the MSI web site doesn't have the pinout for this board. It would be worth a look if you're not sure of what I'm saying here.
Oct 02, 2009 | MSI K8MM-V Motherboard
How to connect power switch on msi ms6787
At the bottom right hand corner of the mobo you'll find there is a set of pins marked JFP 1 and the power switch pins are marked clearly so are the HDD Led, reset, Power Led etc. Plug in your wires which are also marked, corresponding to the marked pins.
Sep 23, 2009 | MSI P4MAM-V SND/LAN/VIDEO (6787060)...
Need of motherboard driver ms-7142
Your board is actaully listed as a model K8mm-V on the MSI website. Here is a link to the MSI page with the correct drivers for your board. These will work for Version 1 or 2 boards:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Hope this helps...
Sep 19, 2009 | MSI K8MM-V Motherboard
Power switch,reset switch,power led connections to motherboard?
Hi ramjet007;
This is strange because MSI doesn't have information on the 7548, since it was made directly for HP. Here is a diagram of another MSI similiar and usually they have their pins on their jumpers pretty much the same. You would use JFP1, And Pin's 1&3 would be the hard drive, 2 & 4 would be the LED, 6 & 8 would be the power switch, and 5&7 would be the reset switch. I know your motherboard is setup differnently, but your JFP1 should be in the right hand corner all by itself.
Front Panel Connectors: JFP1 & JFP2
Good Luck and don't forget to leave a rating.
Thanks Mark
Apr 25, 2009 | Computers & Internet
EMachine MS-7142 board pin connection diagram needed
easy !!!
this is the manual of your motherboard:
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=173
note that MS-7142 is actually K8MM-V (as you can see the filename of the manual is: M-7142.zip
Apr 20, 2009 | Computers & Internet
I need to know the sequence on how to connect my Power LED, Reset Switch, HDD LED, and M/B Switch up correctly. I have an MS-7142 VER:1 Can you help me?
Hi carlmtclem, your not alone when it comes to hooking up the right led connector to the MSI MB. Firstly, you need to know what wire color is positive & which is negative. Most commonly the color white is ground/negative. Wire colors do vary from case to case. So look at your case led wires. Which ever color is common for each 2-pin connector, is negative. (Except the speaker wire).
All other colors are positive.
(The speaker wire color for negative is usually black & red is positive).
Your MSI board has two separate sets of pins.
JFP2 is used for the speaker only. Do not connect the power led there.
Pin one for JFP1 is shown in the manual. Pin 1 is positive & pin 3 is negitive for the HDD-LED, ECT.
Thats it.
Need more information?
Post here.
Good luck carlmtclem!
Thank you for using fixya.
Mike
Jan 11, 2009 | MSI K8MM-V Motherboard
fixya:)
bye
Feb 07, 2008 | MSI MS-6378 Motherboard
MSI KT3 Ultra2-R Motherboard
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=497
Sep 26, 2007 | MSI KT3 Ultra2-R Motherboard
MSI K8MM-V Motherboard Logo
693 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
