Have changed ink cartridge, done several head cleans buts still have broken lines
SOURCE: Removing and cleaning Epson Printheads
I don't know how to remove the print head but if you want to clean it - check for mr.musculo solution from any market near you. Leave the print head in this solution (warmed at about 35 celsius) for several up to 24 hours.
SOURCE: after replacing the black ink nothing prints
Hello, I am having the same problem and have done extensive research to find out that with this exact problem you have mentioned, you must clean the printer head, nozzles, and waste ink tube. the process is a bit long and needs patience. You will have to take the print head assembly out of the sliding caddle and put it in a glass of rubbing alcohol to disolve the dryed ink within the printer head assembly. it is held in with a silver metal plate that runs across the assembly and screws to the sliding carriage. be carefull to remove the black clip on the right of the carriage to take it out. note to be careful to not pull the white info lines of the head. leave it in the glass overnight and also clean the tube that runs under the waste pad station and clean the clear waste tube as well. ....Good luck
SOURCE: Black not printing about every 3rd line
You have the classic single nozzle failure it appears. You say you have done a nozzle check. This should reveal that one of the black nozzles is not working i.e. there is a single gap in your nozzle check printout for the black nozzles. Now, this may be due to a blocked nozzle. Try the following print head soak process.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
SOURCE: EPSON BX300F BLACK PRINT HEAD BLOCKED TRIED TO
If you've cleaned the heads, and swapped the cartridges then it doesn't sound too good.
if you do a google search for Epson Printer Repairers in google with your location so like Cambridge or whatever they'll need to take a look.
You could also check to see if its under warranty - put your serial number in here;
http://www.epson.co.uk/Explore-Epson/About-Epson/Technical-Services/Warranty-Checker/1227954741866
