When i start a wash it clicks and E40 shows up
E40 is an error from the door locking mech (interlock).this is the bit
behind the port hole door frame ,where the door
striker pin goes through hole.hope this helps you.held on with 2 screws
and you need to remove plastic clamp from door gasket to gain access.
E40.door not locking.door interlock faulty or triac faulty on pcb
hope this helps pls do let me know
If this fault appears after you shut the door but before the programme starts then it's worth checking the tightness of the screws holding the interlock in. These are the one you can see with the door open, no dismantling required. If they are loose then the catch (******) on the door can have trouble reaching the interlock properly. If the fault code appears then it's more likely to be a component fault.
The censored word in my reply is a term used by engineers, manufacturers and spare parts suppliers ect. In fact anyone in the trade. It's like "decker" but begins with a "P"...
Sorry, edit. I meant to say "If the fault code appears part way through a cycle then it's more likely to be a component fault."
SOURCE: Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
