Porter Cable Factory-Reconditioned Porter-Cable FC350AR Clipped Head 2-Inch to 3-1/2-Inch Framing Nailer Logo
Posted on Mar 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can My FC 350 A used 28 degree nails
I got this Porter Cable FC 350A framing nailer and the add said it handle 28 degree nails. However when I load them in the nailer it shoot one nail then it jams.
Repair Ahjoshe
Level 3:
  • Porter Cable Master 885 Answers
  • Posted on Mar 04, 2013
Repair Ahjoshe
Porter Cable Master
Level 3:
Answers
885
Questions
0
Helped
642197
Points
2112
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
5 Related Answers
Anonymous
  • 52 Answers
  • Posted on Jan 11, 2009
SOURCE: nail gun will not shoot nails
Lee
Remove the head, take out the blade and make sure its not bent or the tip broke off. Also while out insert the blade into the nose and see if there is any foreign object blocking the blade travel.
Anonymous
  • 52 Answers
SOURCE: porter cable nailer excessive air escaping
your head cap actuator is sticking. since machine sat in a store Porter cable head caps have a tendency to stick due to the head self-corroding inside. They have had this problem for years and never addressed it. After you look at parts schematic and understand where certain parts go,Take head off and remove white plastic actuator in head. Remove orings and wipe them with a rag. wipe the grooves with a rag to remove any build up. If head it corroded spray head with liquid wrench, not WD 40. and let sit overnight reinstall orings and use petroleum jelly or a thin grease to lubricate orings and reinstall actuator in head. Reassemble. Use pnuematic oil on a daily basis.
Anonymous
  • 2176 Answers
  • Posted on Jan 21, 2009
SOURCE: air nailer won't nail
If youve never done anything to it could be a couple things. Have you kept it oiled (about 6-8 drops) before using and again at lunch if construction type work. Check the nails to make sure they move freely in the magazine Check the nail guage for proper size. and what I would do is fire it till it skips disconnect the air from tool and open the front door (for removing jams) and see the driver position. If it is partially down that would be the problem, check the driver for being bent. Lastly remove all nails and just tap the nose on a piece of wood and again check the driver position, if it moves or falls freely then the tool would have to have new rubber which might be a good idea anyway. Get back to me with the model number and I will research and see if they make an o ring kit.
Anonymous
  • 2176 Answers
  • Posted on Oct 10, 2009
SOURCE: looking to buy a manual for a porter cable nail
Go to Dewaltservicenet.com and type in your model number the manual is 13 pages long. If I have helped you with your request would you please rate this response accordingly. Thank you
Anonymous
  • 21 Answers
  • Posted on Feb 14, 2010
SOURCE: Why does my porter cable nail gun FN250B shoot
check the magazine bolts are tight and that the magazine is snug aginst the nose. also be sure you are using 16 gage brads and not 18 gage
Can you use 30 degree nails in a Porter Cable FC350 34 degree nailer?
Yes, you can use 30 degree clipped head nails in the Porter-Cable FC350 framing nailer. The FC350A and FC350B nailers are newer models that specify the 30-34 degree clipped head nails. Make sure that the nails are between 2' - 3 1/2" in length. The manuals for each of the later models do not explicitly list the 30 degree nails. Their specifications page do list the 30 degree nails. See http://www.portercable.com/Products/ProductDetail.aspx?ProductID=11542 and https://www.homedepot.com/p/Porter-Cable-3-1-2-in-30-Degree-to-34-Degree-Clipped-Head-Framing-Nailer-FC350B/203555581 . The manual for the FC350 is available here: https://www.manualslib.com/manual/132288/Porter-Cable-Fc350.html . It is the same as the manual for the FC350B, https://www.homedepot.com/catalog/pdfimages/7e/7e0d0f88-a9e7-4411-ad0f-7fc5c1c1fbaa.pdf .
I hope this helps.
How do I release the trigger lock on a brand new porter cable nail gun
Are you depressing the nose of the nail gun against the material to be nailed first? Without doing this, the trigger will not "unlock". You can read a pretty in-depth review of this nail gun at OnlineToolReviews com Porter Cable FR350A Full Round Head Framing... which might also help.
Adjust nail depth 350 mag framing nailer
To adjust the depth of the nail on the coil 350, refer to the parts list listed below.
The safety foot, refrence # 430 or part # 904930 has a slot head bolt. Back off the bolt and move the safety foot down or up and retighten. If however the adjustment will not move enough to keep the driver from setting the nail too deep, then suspect that the bumper, refrence # 130 or part # 897337 has failed and is allowing the driver to travel down the cylinder further than normal. Easy fix. Remove the head and pull out the cylinder and driver to change the bumper. Good luck
http://www.ereplacementparts.com/porter-cable-coil350-type-coil-nailer-parts-c-129_1658_2177.html
How do i load nails in my porter cable clipped head framing nailer...
Pull lever back on top of clip, slip sleeve of nails into slot, then release lever to push nails forward as you use nails.Make sure you are you the right gage of nail.
1helpful
Was trying to reload nails into my FC350A nailer. My hand slipped and the nail pusher slammed forward. Now I can't move the pusher to add more nails. What's wrong...nothing seems broken
Framing guns are a pain in the ****. It's the coil. Sounds like it broke free or jammed. Only solution is to take it apart. Take your time , not to difficult.
1helpful
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
I need a rafter hook for a Porter Cable nail gun
yeah good luck finding one that fits. I have been looking for 8 years. If I remember correctly the hooks that are sold for frame guns, the hole is to big for the fitting, so what I di is got a new fitting with longer threads and some washers i want to say like 3/4 or even 1" diam. With the right size hole and sandwiched the hook between them. It works well enough, the down side is the the hook will be in a fixed position. So if your right handed the you need to tighen it down so the hook is about 45 to 60 degrees left of center so you will still be able to load nails. hope this helps. Ohh and if the hole in the hook is to small just drill it out and presto. I have had so many frome guns I forget what works on what gun but I think you will find that this is the trick.
3helpful
Wiil a 22 degree Paorter Cable FR350A Round Head
No... it will fire 21-degree nails and perhaps 23-degree nails (but sont think they exist) and it is a full-head framing nailer so it is designed for firing round head nails. Using clipped nails will likely jam the nailer as these nails are stripped closer together with overlapping heads in the nail strip and the FR350A has a full round driver so you will run into issues with clipped nails. If you are having problems finding full round head nails, you can find them on Amazon to fit this nailer. Otherwise any good tool or trade tool store that sells nailers will likely have a suitable nail supply available for the FR350A.
1helpful
2answers
Trouble finding 3 1/2 clipped head nails 34 degrees
You can use the same nails that are used for these nailers: Porter Cable FC 350A, Hitachi NR83AA2, Senco FramePro 701XP, 751XP ,Ridgid R350CHA, DeWalt D51822, D51823, and Paslode F-3505. Make sure you purchase the correct shank nail. Nail length should be 2"- 3 1/2" and the shank should be .113" - .131". I have purchased nails for my FC350 at Home Depot and they are relatively inexpensive. Though you have to buy a case of like 2000 or 4000. The brand of nail is Grip Rite that I purchased. Any questions please post.
Framing nailer intermittently doesn't shoot the nail.
Make sure to blow out the magazine where the nails load, make sure the spring tension on the nail clip is working properly, make sure you're not holding the clip somehow with your off hand so the clip can't feed correctly.
Top Porter Cable Air Tools & Compressors Experts
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
