My furnace isn't producing any heat. I looked at it and I don't see any flame and smell a slight odor of natural gas. I believe the furnace isn't igniting the gas so it turns the gas off after a couple of seconds. Everything else seems to be working, any suggestions?
There is a diagnostic code flashed from a window in front panel of the furnace. What is it? From your description, I would bet on the ignitor as faulty. The vidoe shows this repair. Don't remove elements and sand them as this fixer did. it is destructive in many cases. York Diamond 80 furnace troubleshooting won start won light flame sensor...
SOURCE: Yokr gas furnace will not start up
You could have the gas co to check to preassures at or before the unit. Too low or high a preassure and the gas valve cant regulate the proper flow>>Natural gas to the house needs at least 5"-wc psi ---to the gas valve needs 7.5"--wc and while its calling for heat the orrifice needs 3.5" -wc psi! Propane needs 11" wc psi to the valve on the unit and 11' -wc psi to the inside furnace.
SOURCE: York Diamond 80 furnace (propane conversion),
Check for 24 volts across the two terminals on the gas valve when the ignitor glows. If yes, bad gas valve or blockage in the gas train. If no, bad ignitor or circuit board. Even if the ignitor glows, it still may be bad and not sending the proper signal to the board. If you jump the R and G terminals on the circuit board, does the fan still only run for 90 seconds? If so I would say replace the board.
SOURCE: Gas Furnace - residential -found furnace off - pilot light off -
check ur venting first make sure its not plugged
SOURCE: I have a york diamond 80 heater. The part that
Sounds like your fan switch is defectiveor posibble installed in the wrong place. This switch is heat controlled and delays the fan coming on until there is warm air to blow.
