SOURCE: Can I use a WD3200AAJS
Hello!
The drive you have is a SATA drive, and has no master/slave configuration as such. There is a connector block on the back to configure other options such as spread spectrum clocking. Normal configuration is a jumper between pins 1 and 2 (all the way on the right side, facing the back). A picture of the other configuration options is shown below.
Hope this helps you out,
Ken
SOURCE: i need firmware for Western Digital WD Caviar Blue
If you are troubleshooting a system or OS problem, you should not consider firmware updates until after exploring more typical troubleshooting steps like file system error checking and anti-virus scanning. If you are troubleshooting a system or OS problem, you should not consider firmware updates until after exploring more typical troubleshooting steps like file system error checking and anti-virus scanning. hope this helps you
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this should schedule the task on restart then defragment your hard drive
http://download.cnet.com/western-digital-disk-manager/3000-2122_4-10008018.html
This file contains the most up-to-date Disk Manager drivers for Windows 95 and Windows NT 3.5.1. This file fixes numerous issues, especially those with IBM PS/1 Value Point machines. These drivers will replace Ddloader.bin and Xbios.ovl files that were installed with previous versions of Disk Manager.
