Shark Navigator Bagless Upright Vacuum Logo
A
Anonymous Posted on Feb 26, 2018
Shuts off in the upright position
In the upright position the vacuum continues to run..only the roller stops working..this is normal...however..the vacuum now shuts down completely when in the upright position...it has been thoroughly cleaned and the on off switch seems to not operate only if the roller is in operation
Thatvacguy.com
Level 3:
  • Shark Master 1,619 Answers
  • Posted on Feb 27, 2018
Thatvacguy.com
Shark Master
Level 3:
Answers
1619
Questions
0
Helped
605067
Points
3345
Might be a defective switch.
1helpful
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ‎Review by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Why does The beater bar on my hoover continue to run in the upright position?
Hi there! Some vacuums do not come with the feature that automatically shuts the brushes off when in the upright position.. If your unit is like this, be sure to put the vacuum on the highest setting when using the hose. Also, because the brush-roll continues to spin, avoid tipping cleaner or setting it on furniture, fringed area rugs, or carpeted stairs during tool use. Hope this was helpful!
Roller brush spins
The roller brush will turn as long as the sweeper motor is running no matter what brand you have. Turn it off as you return it to the upright position.
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Power stops when vaccum is in upright position or when trying to use the wand.
When you stand your DC17 upright, the brushbar motor is designed to shut off. However, the suction motor should continue to run until you turn it off with the red on/off switch. If your cleaner shuts off entirely when you stand it upright, it's probably best if you get in touch with us directly so we can provide further assistance. You can reach us by calling free on 1866MYDYSON. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
6helpful
Vacuum roller stops turning
with cleaner plugged in and turned on, push the little reset button on the side of the lower base of vac. Remember that the brush will not turn in the upright position. release your handle and you should be in business. hope this helps. please let us know. thanks renevacdoc
Roller brushes siop after a couple of seconds
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
87uyf
Brush roller does not turn off in upright position
make sure there is not a lever to move in order to stop the brushes/agitator...
if the belt makes contact with the end of the shaft the brushes will rotate...
tighten all of course/and take the panel of to check behind the bag to make sure all is tight. (fasteners)
take off the face plate to make sure that the adjustment for the floor tools is not broke and belt is ok.
2answers
Dyson DC07, too much suction...?
sounds like one of the filters is either damaged IE a hole or tear or is not seated correctly
Top Shark Vacuums Experts
vince
Paul Carew
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
