Oil burner seems to ignite and burn fine at first but after a half hour or so oil starts to run down between the burner and the furnace body
SOURCE: smoke from back of engine after it is shut off
Well This has happened to me also. When I looked there was no oil anywhere but when I removed the head gasket, I took it appart and there was a very tiny crack which leaked oil directly onto my Manifold. So once my car got hot the tiny crack let out a few drops which smoked after the manifold gets really hot. As for yours I am not sure but i suspect its that. As for a fix I dont know one. I put my motor back together and ran it for a long long time (Trusty Volkswagen)
SOURCE: engine shut down after 15miles then won't start for half hour
just went thru the same think wit a s 430 it was the crank position sensor . 60 bucks at auto zone and it took me 5min. 2 install if u need help feel free to call me 918 808 9706 chris
SOURCE: Lumina still won't start until engine cools down for an hour
The coil pak is probably bad.
you need three things to start air fuel and spark. You turn it oven and it wont run,if the fuel is the problem try this.spray a little 2+2 carb cleaner down the throttl body if it runs ,fuel is the problem.
It can also be as simple as the ECM the computer could be going bad.
SOURCE: I added some old oil that i found to top off the
i know of no oil that would cause this. anti freeze mixed with oil will. i suggest that you change oil and filter before you run it again
