Need disassemble instructions to replace belt
SOURCE: magic chef dryer quit working
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
SOURCE: Magic Chef electric Dryer won't start
Do you have power going to the receptacle. You can first go to your house panel and look for the circuit breaker for the dryer (usually a 30 amp 2-pole brkr.). It could be tripped. So first, put your dryer in the off position. Next, go back to your circuit breaker in your house panel. Turn off the breaker, and then turn it back on. This should reset the circuit breaker for the dryer. Then go back and try turning on your dryer. If this doesn't work, feel free to contact me again. However, this would seem to be it. Good Luck to you!
SOURCE: Magic Chef YE228LV Dryer schematic
dryers only have 1 heating coil and it is located on the back inside panel of the dryer. Before you go taking you dryer's heating coil out please check the temp relay. now some dryers have 2 of thoses they will be on the heating coil case and look like silver button and usually have 1 or 2 wires on it. If the dryer will not dry as well as it use to than what may be happening is that the relay my not be working properly and telling the heating coil to only come on for a short time and than shut off again. now the relay's are the cheapest thing to fix. i would start with thoses. if that does not work or ou need more help please contact me again and i will assist you with disasembling you dryer to get to the heating coil.....
SOURCE: how des the belt go back on
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
SOURCE: Magic Chef Dryer runs fine but Squeaks loudly
this sounds like a drum guides that need replacing soon.
