There is no visible external battery connection when I lift up the gas cook to to examine it underneath
SOURCE: Magic Chef Gas Oven - Heats up slowly and has intermittent gas smell
STOP USING THE OVEN IMMEDIATELY!!! You are not getting enough air to the burners to burn all the fuel. Not only will you have an explosion hazard, you'll have a carbon monoxide hazard either of which will KILL YOU. Read all of the info below before you begin.
You need to clean all the burners and inlets thoroughly. You probably used the oven for a lot of broiling of meats or it is quite old. The deposits are clogging the tubes which gauge the amount of air entering the burners or the burner holes themselves. The burner tubes are generally removable by removing one screw and giggling the units clear. Before taking anything apart, note carefully the positions of any mix plates and scribe small marks between the two surfaces. Use a heavy duty cleaner or WD-40 to loosen grime. Don't use abrasives like Comet. Then wash in mild detergent with hot water and dry. Be sure all burner openings are clear. After assembly, note the color of the flames. They should be about 90% blue along their length from the burner head. If they are not, you didn't finish the job cleanly or you have another problem. If the burners are old, rusty or have irregularly shaped flame holes, replace them.
SOURCE: replace the switch lighter for magic chief cook top
I would like to replace all gas head(4 sets) of the Magic Chief gas stove in Thailand. How to find the service center?
SOURCE: Can't get cook top open
Hi, the burners turn counter clockwise. they hold the burner to the top panel. Those need to be removed. Most of the time the tubing is disturb like this, they need replaced as well. Please let me know if this helps or if I can assist you further.
Thanks
Vic
