Frozen in record mode and TV will not work. I want to use just the TV
SOURCE: TV shuts off in 5 seconds
El problema es la casetera esta fuera de tiempo probablemente necesita cambio de la banda del carro.
SOURCE: Emerson EWC 1302 Tv/VCR combo shuts down
I've seen problems like this with 2 tv/vcr combo sets before. in my case each time the sensors in the machine think there's a tape jammed, and it shuts down to prevent damage. if tihs is what's going on it should actually say onscreen that it's trying to eject a tape, whether there's one in or not.
WARNING: this fix may get the tv working again, but the vcr will not be usable.
if this is what you're seeing then step one would be to remove the tape (assuming there's one there at all), now turn it back on and see that: THIS DIDN'T FIX ANYTHING! that's where step 2 comes in, you need to probe around a bit, in my case this was very much a trial and error thing, and find which mechanical parts are in the wrong positions. you want everything in the position it should be with a tape ejected. with this done you should be able to turn the tv on without getting the eject message and having the tv turn off.
SOURCE: Remote codes
http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
thats pdf i got my info off of
SOURCE: programming cable channels for emerson tv vcr dvd combo
To see RCA's code list you probably need their website but Emerson is one of several names now owned and built by Funai, who also builds Symphonic & Sylvania.
You might want to try those codes with your set.
