SOURCE: a pink line is on every page printed
This is a very common problem with this model printer, it is caused by toner on the scanner mirrors. You need to clean the scanner assembly unfortunately it isn't very easy to dissemble the printer to get to it.
SOURCE: BLINKING ORANGE LIGHT AND NO PRINTING
I just experienced this with my 920c. I cleaned the contacts in the cartridge holders with alcohol and the problem went away.
SOURCE: The orange light is flashing and I am unable to
it is problem printer cartridge change it then solve it
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the
printing problem..
# Hold the cartridge upside down, with the
bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the
cartridge on the bottom (where the ink comes out). Wipe the printhead
horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure
the ink is flowing.
# Next, look inside the printer and locate the
carrier that holds ink cartridges. Caution: Make sure the cartridges are not
installed at this point.
1. Look for a shiny piece of metal underneath the
contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and
wipe along the bottom of the shiny metal piece. Note: You may need more than
one swab.
# Reinstall the cartridges, making sure you snap
them correctly into the printer.
Hope this help. Please
Rate My Response! Thanks!
SOURCE: HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
Confirm there is no orange tape across the top of the ink tank
If the orange tape is as shown in Figure (A), it is properly removed.
If the orange tape is as shown in Figure (B), remove the remaining tape to the level shown in Figure (A).
Make sure each ink tank is snapped into the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
