Hmmmmmmmm. If the water goes in and the pump starts yet there is no washing action I would suspect that you have an impeller failure. The impeller on Bosch dishwashers is a two piece unit and the plastic rivets slowly dissolve until he impeller fails in 2 pieces. The fix is a new impeller which is supplied with a new seal as well. I believe Bosch does this to avoid running so long without renewing the seal and having a leak. I can't think of any other reason to have a dishwasher soluble part for an impeller. It's a bit of a bit** to fix but there are good videos on utube.
Water leaking can be poor plumbing or fault in the inlet hose connection. You are the first observer and so your view on the leak area is important as the leak can be from the hose, from the inlet, the hose or the washer unit.
Based on this the water leak can be plugged, tighten the hose clips, check the inlet filter or check the washer's feed line.
I dont know what brand your dishwasher is, but if it is leaking from the two bottom corners it is not level. If the back is higher than the front, the water will drip out of the bottom corners of the door. Raise the front feet up so that the edge of the door is flush with the cabinet doors from the top to the bottom.
Hi
Thanks for using FixYa. If you
have nuisance water leaks around the base of your dishwasher, you may be using
a detergent that is causing too much suds. Cut back on the amount of detergent
you use, and see if that makes a difference. Water that spills through the door
vent is usually caused by improperly loading dishes. Leaks from the door itself
may be caused by a faulty door gasket or door tightness adjustment. you should
check the main tub seal, the door latch, the door gasket, the water-inlet valve,
and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet
up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose
connection. Remove the lower front panel, and check the hoses. The pump seal
may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If
this is the case with your dishwasher, it's time for a new one.
Please do rate the solution if the issue is resolved or
else revert for further assistance.
just an idea...if i'm understanding you correctly,could the door seal be creased there or folded over by use and age to permit this to happen? cause you said nothing is missing
you are not getting enough water inside of dishwasher.you can pour 1gal of water inside. to see if arm work better should be 3 or 4 inches of water in side of dishwasher. water valve maybe bad or dirty screen inside of valve.ck to see if enough water is in bottom of dishwasher.ck to see if flote switch in left front corner of dish washer is moving up and down.
