Will turn on but no dehumidifying so there is no water in the bucket.
well 67%rh is considered low (70%rh is normal) units will produce much less water when tasked to operate in low moisture air , this is why all the new units have air temp ratings of 60Deg or less. but still the unit should try to go thru all the motions ,that you can easy verify , just by u watching /listening closely
set unit to work normally , listen 4 the fans inside to come on and a few moments later the compressor will come on if everything is working well , try adjusting the humidistat up to a value of say 80% listen 4 one fan and compressor to stop , this is all normal reset desired setting on humidistat
if unit fails any one of these simple tests it has an internal fault inside it and requires service
