SOURCE: Need the remote control code/s
I google'd remote codes for this device. code 1007 seems to work as far as volume controls and the off/on switch goes.
SOURCE: looking for remote code for sherwood rx4105 to work with comcast
Ask the remote code experts -
They will get it for you.
http://manualfox.com
SOURCE: trying to program my At&t Uverse remote to my
Sherwood
Receiver/Amplifier
5027
Sherwood
Receiver/Amplifier
5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
All the Mode keys should flash twice.
SOURCE: SHERWOOD RECEIVER 6108. I
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on. Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up. You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it. If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good. If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech. Check for loose speaker connections as a root cause for intermittent shutdown.
