IMO Never Use a cleaning disc for Gaming consoles. Which Xbox 360 do you have? Is it the Older Model or newer one? You can Try Blowing into Your Xbox disc drive. Is your xbox up to date,you can unplug your xbox 360 and from the wall and the Xbox. Wait 25 Mins and Try again.
as you said jvc lcd tv won"t show. if lcd tv have good power supply & main board. that will be inverter board gone in. replace it will be solve you problem. good luck!
I think the content is too high definition. If you're using component, like i am, it plays the lower resolution videos just fine, but higher resolution videos won't play. But when it's connected to an LCD tv, it works just fine? Must be that.
If you have the AV cable that has the switch on the Xbox end, make sure that it's in the correct setting. Your cable could have shorted out if this does not work.
That is a peculiar device for doing that. It doesn't like some types of files and with video it's got to be VERY delicately encoded or it won't work. You need to have your PC up and running, when you load your xbox (at least with Vista and Windows 7) it should pop up by your clock a bubble saying "Media Extender available" click that and you should get some instructions.
Yes the display settings need to be reset since he had HDTV and you don't. I do this by simply having the PS off then press power button and hold it for 5 seconds.
