Is it possible to connect my Altec ACS48 speaker system to my TV?
If your TV has audio output jacks, then yes, you can connect your speaker system to the TV. Run a stereo RCA cable from those output jacks to the audio input jack on the Altec system, using whatever adapter required. You will probably need to convert from RCA jacks to a 1/8-inch stereo plug for the speaker input. Or you can pick up a cable from Radio Shack that has the RCA plugs on one end and the stereo plug on the other, and omit the adapter.
If the TV doesn't have audio output jacks, there isn't any easy way to hook up the Altec.
Please take a moment to rate this solution if it has helped you. Thanks for asking here!
