I have a Honeywell HE 220a. I am having trouble keeping humidity levels in my house above 23%.We have exteremly high calcium in our water.My supply line is tapped into cold water.Would changing to hot water supply help?
Hi, Hot will make the problem worse. If your calcium is that high you will have scale in your tubs, sinks and toilets. Calcium is a pipe clogger and if you have noticed this type of scaling you may be wise to consider a whole house water filtration system, it will save you lots of problems in the long run. Good Luck!
